no left low beam no driving lights
Old Mar 15, 2020 | 07:41 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by byteme
thanks for straightening that out , any idea why the lights dont work >>?
Can you do basic testing with a test light and multimeter? If so get the FSM from the FAQ section. Wiring is in 8W. The common failures are: multifunctional switch, wires pulled out of the multifunctional switch if you have a tilt column, headlight switch, or ground(s). Without doing any testing you are throwing parts at it.
Old Mar 16, 2020 | 07:05 PM
byteme's Avatar
byteme
i tested for voltage and none was looking for answers and saw many people saying headlight switch so I figured for the money toss on a used one , so you think if a wire (1) is off on the multi switch it would stop voltage to the left headlight low beam and the driving/fog lights seems weird ...
Old Mar 16, 2020 | 07:27 PM
MoparFanatic21
There are spices where the wire can go bad. The fog lights could be the relay. For the headlight start chasing the low beam wire
Old Mar 17, 2020 | 04:06 PM
byteme's Avatar
byteme
thats the plan ill switch out the relay and see but it all started at the same time
Old Mar 17, 2020 | 06:19 PM
MoparFanatic21
See if they share an wires, if so that is where I would start.
