NV4500 swap into 1500
Old Mar 14, 2020 | 05:48 PM
CommiCommander's Avatar
CommiCommander
Default NV4500 swap into 1500
Alright yall, brand spankin new here so bear with me with i goof this up, anyways, i got a 96 Ram 2500 Light duty donor truck for my 1500. Im putting the NV4500 from the 2500 into the 1500. Any major things i should watch out for in the prosses? Both trucks have a 5.9L engine.
Old Mar 14, 2020 | 07:07 PM
2bit's Avatar
2bit
Damaging the crank sensor if you have the flywheel off.
Old Mar 14, 2020 | 09:46 PM
Yep. This one. Also, keep in mind, if you are going from auto, to manual, the crank sensors are different. Need the correct one for the manual trans.
Old Mar 15, 2020 | 02:53 PM
CommiCommander
Is that sensor affixed to the transsmission or the backside of the engine? The donor truck was a running driving 2500 w. NV4500 that didnt have a single straight body panel
Old Mar 15, 2020 | 05:06 PM
Bolts to the engine, but, there is a cutout in the trans for it. Behind the passenger side head. Yep. It's REAL fun to get to.
Old Mar 15, 2020 | 11:08 PM
CommiCommander
Alrighty, thank you for that info, i will let yall know how the swap goes, so far have the clutch and pedals into the truck next steps the trans and crossmember mounts and drivelines(which is gonna suck)
