Crank but no start
Old Mar 16, 2020 | 12:06 AM
Jourdain's Avatar
Jourdain
Default Crank but no start
So I have a 2000 1500 5.9 and I was sitting at a light and went to go take off truck stalled out then took awhile to start had to push gas peddle and turn the key to get it too start. Had my battery gauge jump to 18v that same day. Now the truck won’t even turn over any ideas on what’s going on
Old Mar 16, 2020 | 12:50 AM
master tech's Avatar
master tech
Site Moderator & Tech
Have you try turning the engine by hand with a breaker bar and socket? If the engine spins with the breaker bar. I would check the battery and cables next and also check how much voltage getting to the starter and check the ignition wire at the starter too.
