Weird ticking noise?
Old Mar 25, 2020 | 03:53 AM
JT brentlinger's Avatar
JT brentlinger
Default Weird ticking noise?
I have a 1998 1500 with a 5.9L and it starts to make a ticking noise at around 40 mph and gets louder the more stress the engine is under(going up hills or accelerating faster) and sometimes the cylinder 8 will misfire but not every time and the code will go away a couple hours later. I have replaced spark plugs and wires as well as the distributor and cap. Any suggestions?
Old Mar 25, 2020 | 07:35 AM
Checked the Plenum?
Does it sound live valve noise, spark knock? Is it indeed coming from the engine?
Old Mar 27, 2020 | 12:20 AM
JT brentlinger
Checked the Plenum?
I have not replaced the plenum but the truck has a brand new motor and transmission with under 20,000 miles on it and the mechanic I taken it too said that there was no vacuum or gasket leaks but I checked the plenum thread and it basically has all the symptoms of it.
Old Mar 27, 2020 | 07:41 AM
Check the plenum then. Also checked for a clogged cat.
