Lockup torque converter q&a
Old Apr 2, 2020 | 11:51 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Sledder10
98 1500, 5.9, 3.55s rv cam and tune on 91/92 octane. Plenum fixed, failed, did it a second time with aluminum plate, still mild pinging under heavy load. It originally had a 5.2, swapped that including pcm. The front o2 was replaced (pretty sure I did that when I got it...might want to verify) and replaced cat and y pipe. 31.5x10.5 tires, nothing crazy, on it when I bought it. I have a code that popped up something to do with the evap after the swap, haven't dealt with it yet.
Hopefully I'm not showing my ignorance here, I've seen all the "don't tow in od" directives, but I kind of assume that meant "don't push it very hard in od". If I'm chugging along on flat ground with no headwind, I selectively have it od. I just feel that two quads on a utility trailer (granted steel not aluminum) shouldn't be asking that much. I've considered regearing I just don't tow heavy enough often enough to justify the cost.
Towing on a flat in O/D is acceptable. That really isn't a lot of weight. I barely use OD on my other Rams but you have to remember that some of these trucks had a weak trans from the factory but I think you'll be fine. Listen to Get you as he knows more about transmissions than I do. To test the torque converter, you can do the stall test. A common symptom of a failing TC is slow acceleration from a stop but good acceleration on the highway.
Old Apr 2, 2020 | 11:53 AM
Sledder10's Avatar
Sledder10
I mean, acceleration sucks all around lol. I'll look into the stall test. I have the factory transmission cooler which I am looking to upgrade, if anyone has recommendations I'll take them, I know most are generic.
Old Apr 2, 2020 | 11:55 AM
MoparFanatic21
Factory cooler isn't bad (remove the check valve) especially since you don't the heavy.
Old Apr 2, 2020 | 12:00 PM
Sledder10's Avatar
Sledder10
When I got the truck, the cooler was laying (still connected) in the valley beneath the condenser in the bumper. I've rednecked it up so it's getting airflow but figured to fix it permanently I'll just get a little bigger cooler while I'm at it.
Old Apr 2, 2020 | 12:03 PM
MoparFanatic21
You can (wouldn't hurt) but just wanted to inform you it's not needed . It should be between the condenser and radiator.
Old Apr 2, 2020 | 12:05 PM
Sledder10's Avatar
Sledder10
That's probably why I couldn't figure out how it was supposed to mount. Just assumed someone stole the brackets or something.
But it probably is more efficient in the front, ac isn't hooked up anyways.
Old Apr 10, 2020 | 12:21 PM
Sledder10's Avatar
Sledder10
I did my stall test. First came back 2400ish then 2200ish. Seems a little high from what I've read. If it is high that could mean....?
Old Apr 10, 2020 | 01:11 PM
Stall speed is a pretty generic spec. Different engines will show different stall speeds for the same converter. Are you sure its a stock converter?
Old Apr 10, 2020 | 01:50 PM
Sledder10's Avatar
Sledder10
No, a non stock converter was actually a suspicion. Supposedly the transmission was rebuilt before I got it, and I bought with 190k, and it seems to operate smoothly overall, so I believe the rebuild story. Also reportedly had oversize tires, so another reason its likely to have needed rebuilt.
I'm not there yet, but if I was to get a different converter what stall should I shoot for? Main use is towing 2-4k.
Old Apr 10, 2020 | 02:17 PM
MoparFanatic21
Id it's not stock that test is useless
