Rear axle fitments
Old Apr 14, 2020 | 02:12 PM
HeikIlm's Avatar
HeikIlm
Parking brake cables and brake lines going to the calipers.
And maybe master cylinder? Anyway, still heaps easier than converting to drums.
Old Apr 14, 2020 | 07:03 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I would not think as the rears still only do about 30% of the braking. If OP wanted to replace it I would do hydro boost
Old Apr 14, 2020 | 08:28 PM
Disc brakes are more efficient though, and also require a larger fluid volume. Probably a good idea to check part numbers, and see if the master is different. I would bet money that the proportioning valve is different though.
Old Apr 15, 2020 | 11:41 AM
Mike Holmen's Avatar
Mike Holmen
The worst thing about running rear disk brakes is that they usually get rocks/debris stuck in between the rotor/caliper, I prefer drums as I do lots of gravel/muck driving. Drums will less maintenance than disks, but if you tow heavy you need large disk brakes/engine exhaust brake,
Old Apr 18, 2020 | 06:35 PM
Sledder10's Avatar
Sledder10
You want a corporate 9.25 rear diff, every 1500 truck will have one. Ideally, you want something from a 98 to 01, older axles will work, going back to 94, and maybe even earlier, but, I think the rear wheel speed sensor connector is different. Just need to swap out for the correct sensor. (steel the one out of your rear end.)
I picked up an axle from an 01. However I didn't look close enough. The 01 has a flange that I unbolted the driveshaft from, while my 98 does not - its just shaft to u joint to pinion yoke. I don't have all the right terminology I'm sure. Can I just pull the pinion nut and swap the assemblies?
Old Apr 18, 2020 | 07:12 PM
MoparFanatic21
You can, but you have to make sure you get the rotational torque in in pounds. Then remove the nut and make sure you tighten it slowly and get the same rotational torque.
Old Apr 18, 2020 | 07:14 PM
Sledder10's Avatar
Sledder10
Torque of... What? The pinion nut?
Obviously I haven't done this before, kind of the goal of a drop in... Lol
Old Apr 18, 2020 | 08:55 PM
MoparFanatic21
You pull the tires, drums, and rear driveshaft. Spin the pinion with a in lbs torque wrench. Get a reading. Then you tighten the new pinion nut slowly until you spin it and get the same reading. If you don't you'll ruin the rear end. Best best is to just get that flange for your driveshaft
Old Apr 19, 2020 | 06:38 AM
HeikIlm's Avatar
HeikIlm
Get the flange for the driveshaft, much easier than swapping the yokes and it might even fit to your existing u-joint. But considering the u-joints wear out over time, might as well get the new quality u-joint, such as Spicer.
