1998 ram 1500 4x4 nylon fuel line kinked at tank
Old Apr 23, 2020 | 03:46 PM
nedhlp7's Avatar
nedhlp7
Default 1998 ram 1500 4x4 nylon fuel line kinked at tank
does anyone know how to repair nylon fuel line and connector that goes from the fuel pump inlet to steel line at frame? the line got twisted and kinked up a bit while trying to get quick connector off. can it still be used after kink is straightened out or should it be replaced? does anyone know what size the connector and nylon line is? or if dorman makes a fuel line/connector repair kit and what the kit# is.
thanks in advance
Old Apr 23, 2020 | 04:43 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
thanks in advance
You can save the end by using a heat gun and heating up the nylon line, then pull the end out. No you have to replace the hose as once nylon kinks it retains the link. Don't remember the sizes. Dorman makes a nylon fuel line repair kit but it's over $200. Napa sells the line and fittings.
Old Apr 25, 2020 | 09:18 AM
Moparite's Avatar
Moparite
Yea, Dont know if any of you actually tried one of them before but it's a pita! You are supposed to put the line in HOT water to soften it up so you can work with it. I had it in boiling hot water and still kinked. Just got regular fuel line hose and called it a day.
Old Apr 25, 2020 | 11:28 AM
primem's Avatar
primem
jobbers sell plastic to plastic fuel line unions and plastic to steel unions. cut out the kinked section and replace it with either plastic or steel line.
Old Apr 25, 2020 | 08:49 PM
MoparFanatic21
I used a heat gun and a brake line flare tool (the holder) and ran all new lines on my truck.
