axle to driveshaft
Old Apr 25, 2020 | 04:29 PM
jaze5736's Avatar
jaze5736
Default axle to driveshaft
ive noticed that there are 2 different types of of drive shaft mounts to the axle. Some have the plate with the 4 bolts like in this top picture and other do not have it like the one on the bottom. how do you convert from one to the other?
Old Apr 25, 2020 | 05:26 PM
It's just a different yoke on the pinion, and either nothing, or the corresponding flange on the rear u-joint. I think it changed in 00??
Old Apr 25, 2020 | 08:13 PM
Torxhead's Avatar
Torxhead
Converting helps if you have a local driveshaft shop to go to.
Old Apr 26, 2020 | 01:09 PM
jaze5736's Avatar
jaze5736
i am putting a 99 axle into my 01. will i have to buy a different drive shaft?
Old Apr 26, 2020 | 02:05 PM
HeikIlm's Avatar
HeikIlm
No. Option #1: If you have the old axle, take off the yoke from 99 axle and replace it with the flange from the 01.
Option #2: Remove u-joint flange from the 01 driveshaft, and bolt the u-joint to a yoke. Make sure the u-joint fits to the yoke, or get the correct u-joint.
Old May 15, 2020 | 12:04 AM
jaze5736's Avatar
jaze5736
If i remove the yoke by removing the large nut will that do anything to the internals of the diff or is it just a quick way to remove the yoke and swap on the 2001 yoke
Old May 15, 2020 | 12:48 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I replied in your thread. But yes it affects pinion preload and you need to follow the procedure in the FSM to a tee.
