73 203 Transfer case
Old May 4, 2020 | 05:56 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by HeikIlm
Borrowed this picture of the stock NP203 range box from the CK5.com site:
https://ck5.com/forums/resources/ord...nsfer-case.72/
There's a shift collar for hi/lo range inside the case. Under that is low range gears on the countershaft. Low range consists of gears set of four. Biggest gear mounts to a intermediate shaft, which is not pictured, and is almost a size of that hole. In order to get 4:1 gears it would have to be much, much bigger. And as it can be seen, just impossible to fit in there.
Maybe it's a custom case like Heik said I'll message the guy and see what he said
Old May 4, 2020 | 09:06 PM
I tthought the 203 was a full-time 4wd, chain driven case. The 205 was gear drive???
Old May 4, 2020 | 10:34 PM
HeikIlm's Avatar
HeikIlm
Yes, both corret.
Old May 5, 2020 | 02:10 PM
MoparFanatic21
So the guy got back to me and said he doesn't know it was his dad's. I thought the case looked to new, but again I did verify it has 4.10 by engaging low and spinning the input shaft.
