HVAC Box
Old May 15, 2020 | 09:30 AM
Dhalas818's Avatar
Dhalas818
Default HVAC Box
Two questions. 1st there is this white thing in here corroded and cracked is it replaceable, what purpose does it serve. 2nd is the blend door supposed to move freely like the door next to it. Appreciate the help.
Old May 15, 2020 | 09:42 AM
Ramman18's Avatar
Ramman18
White thing is the blower motor resistor. Yes, replaceable.
Both doors should move freely. One mixes outside with inside and the other mixes cold and hot.
Old May 15, 2020 | 10:53 AM
Dhalas818's Avatar
Dhalas818
blend door did not move freely. dropped motor and found plastic insert that connects motor to blend door is cracked. got room on box to run a thick bead of epoxy around it and re-insert. Can't justify $35.00 plus shipping for Heater Treater fix.
Old May 15, 2020 | 10:57 AM
Dhalas818's Avatar
Dhalas818
If there is no power to servo motor then blend door should not move am I correct on this statement?
Old May 15, 2020 | 01:16 PM
Ramman18's Avatar
Ramman18
I suppose. The motor connects to the blend door actuator so if it doesn't move, door won't either.
Old May 16, 2020 | 08:19 AM
Moparite's Avatar
Moparite
Keep in mind there are two different hvac boxes, The earlier ones had a cable where the newer ones use a motor. Helps to add truck info.
Old May 16, 2020 | 05:02 PM
Dhalas818's Avatar
Dhalas818
Thanks!
