Help on Slave Cylinder
Does anyone know how to bleed a slave cylinder and how to put it in? I have a new one, put it in and it leaks fluid when you press on the clutch. But I don't know how to put the o-ring in, wether it goes on the hose or inside the slave cylinder. I really need help on this one guys, its the diffrence on getting the truck goin down the road, or it sitting at the house. Help!!!
Well I fixed the leaking problem and that is finished. But Im not getting any pressure to the clutch, like it won't disengauge or anything. There is no pressure to the pedal. I don't know what else to do and I will probably take it to a friend of the family's to fix it unless anyone know how to bleed it so there is pressure.
