A/C System
Replacing the Evaporator and Accumulator and manual states to add refrigerant oil to both. Is this something I should do or can it be done by mechanic when system gets tested for leaks and recharged? Appreciate input, thanks!
Put the oil in the receiver/drier/Accumulator when you(or mechanic) installs it. The oil is all in the whole system so when you remove a component you need to put the oil back in. It's a but of guess work and i think there is a chart somewhere that tells you what to add for what component.
Depends of the machine that mechanic uses. We have two different machines at work, and I can add oil with both of them.
But if you add oil by yourself, you can get away from guess work about correct amount by draining the old components to a cup, then add that amount and some more because you can't get all the oil out.
