1999 ram cruise control
Old Jun 11, 2020 | 07:32 PM
scotchbro's Avatar
scotchbro
Exclamation 1999 ram cruise control
Cruise indicator light does not come on when button depressed for cruise control,have checked all fuses in side panel and under hood.everything is good. Knowledge and or suggestions would be appreciated
Old Jun 11, 2020 | 08:22 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
There things are going on and this is the order I would check them.
Bulb in the cluster is out
Cruise buttons are bad
Wiring issue
Old Jun 12, 2020 | 04:05 PM
scotchbro's Avatar
scotchbro
Question transmission downshifting problem
Thanks, bulb in cluster is good,comes on when you first turn on truck. I will be checking switch next..another thing,changed trans fluid, govenor and shift solenoids. When at highway speed 65 or so,step down on the peddle to downshift and transmission cycles back and forth and won't stay down shifted to pick up speed before it shifts out.Fluid is full,have checked for vacuum leaks, can't find any.Thinking maybe torque convertor?, or is there another solenoid somewhere?
Old Jun 12, 2020 | 05:09 PM
HeikIlm's Avatar
HeikIlm
Start by checking the tv-cable, so that it has the correct adjustment.
