96' 5.9 Ram oil Fluxuation
Old Jun 28, 2020 | 08:26 AM
Moparite's Avatar
Moparite
Check if you have spark when cranking.
Old Jun 28, 2020 | 05:49 PM
racerxv6's Avatar
racerxv6
will do. I just finished changing out oil pump as a precaution because of the oil fluctuation...ran out of sun. Rain moving in.. Will report back later.
Old Jun 28, 2020 | 05:50 PM
racerxv6's Avatar
racerxv6
thanks for the size MoparFanatic...
Old Jun 28, 2020 | 08:21 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
No problem!
Old Jun 29, 2020 | 09:13 PM
racerxv6's Avatar
racerxv6
Well, time to take the front of the motor apart. At TDC with #1 up, the rotor was pointing to plug 4 on the cap. She definitely jumped time.
Old Jun 30, 2020 | 10:20 AM
Wow. That's pretty bad....... Get yourself a good double roller timing set to toss in there, change the waterpump/hoses as well.
Old Jun 30, 2020 | 09:52 PM
racerxv6's Avatar
racerxv6
Got a cloys double roller on order should be here Friday, Water pump also. Hoses are only 6 months old so they will stay except for the small hose going from intake to water pump. That was original so it will be replaced as well as o-ring in inlet hose for heater.
Old Jul 1, 2020 | 04:24 PM
I picked up a new steel pipe for the heater line, (mine had rusted in half.....) in the help section at advance auto. I think it was less than ten bucks.
Old Jul 1, 2020 | 06:43 PM
racerxv6's Avatar
racerxv6
My pipe is I good shape and I have an array of o-rings, so hopefully I can find one that matches.
Old Jul 1, 2020 | 09:17 PM
The problem I had when replacing one, was the hole in the water pump had some rough edges, and getting the o-ring past them, without damaging it, was not easy. Couple seconds with a die grinder to clean things up a bit, and it went right in, and did not leak.
