Coolent leak source
Old Jul 17, 2020 | 07:12 PM
Edwin D's Avatar
Edwin D
Default Coolent leak source
Violent
I haveIhave aha 2000 ramaram 360 5.9 coolant leak that does not appear to be coming from the water pump or a hose. It appears to be coming from the mounting bolt to where the power steering pump connects. it doesn't look like it's the water pump and I don't see any coolant hoses close by.
Old Jul 17, 2020 | 09:15 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Edwin D
Violent
Probably bypass house
Old Jul 18, 2020 | 06:24 PM
Edwin D's Avatar
Edwin D
Default No pass hose
Is the Bi pass hose right where the power steering pump attached to the motor ! I don't see a hose there. But water comes out or drips down to the metal between the pump and the motor .
Old Jul 18, 2020 | 08:32 PM
Its above the timing cover. Coolant pools on the top of it, then runs down in various spots. Pull the a/c compressor out of the way, have a look at the hose, and the cover itself.
Old Jul 22, 2020 | 01:45 AM
Gen2Guy's Avatar
Gen2Guy
Cool
What HeyYou is talking about is the tube that is coming out from above the water pump and under your air conditioner that connects to a 3/4~1 inch hose that goes to your cab heater.
It's bolted in place with a single mounting bolt and is basically a straight pipe with an o-ring on it to seal it. The o-ring goes bad after a while and causes a leak.
If you are talking about the actual top mounting bolt of the power steering pump...well that's bolted directly into the engine head, and may penetrate a water passage...I don't know, but it would be easy enough to find out..just loosen the bolt and see if it gets worse. That bolt by the way is also your main engine ground..so you don't really want it getting soaked to much.
The leak may also be coming from where the hose is clamped to the bypass tube (cab heater tube).
