After Market Fuel Pump
Old Jul 21, 2020 | 08:25 PM
racerxv6's Avatar
racerxv6
Default After Market Fuel Pump
Ok guys, sorry for all the new threads. I replaced my fuel pump a while ago and ever since the fuel gage has stopped working. it gets power just always shows empty and fuel light is on. Do you all think that the aftermarket is the issue?
Old Jul 21, 2020 | 09:16 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Could be. Did you index the pump to the tank?
Old Jul 22, 2020 | 07:16 AM
Spillage's Avatar
Spillage
When I did mine, the float arm jumped over the stop so it couldn’t rise with the fuel level.
Old Jul 22, 2020 | 09:10 PM
racerxv6's Avatar
racerxv6
Uhhhh. nope...
Old Jul 23, 2020 | 10:40 PM
racerxv6's Avatar
racerxv6
so, what do you mean index the pump. I've never done that before when changing a pump.......
Old Jul 23, 2020 | 11:45 PM
MoparFanatic21
There is an arrow on the pump and 2 lines on the tank. The arrow has to be in those lines
Old Jul 24, 2020 | 06:24 AM
Moparite's Avatar
Moparite
I don't remember any arrow or lines when i did mine. But i always mark the old one before i remove it. If i recall the the float goes towards the front.
Old Jul 25, 2020 | 09:17 AM
racerxv6's Avatar
racerxv6
So, when I replaced it I placed everything back in the same position. I did not notice lines of course I wasn't looking for them either. I think I will remove the bed and check everything. if that doesn't do it. Then I will be purchasing a mopar pump.
Old Jul 25, 2020 | 09:56 AM
MoparFanatic21
If it is indexed correctly, before buying a new pump, pull the pump out and lift the float whole someone watches the gauge with the key on. If it works then you know either you got sold the wrong pump (there are 2 different pumps) or the float is hitting the tank.
Old Jul 26, 2020 | 04:16 PM
racerxv6's Avatar
racerxv6
Thanks MoparFanatic21, I think I'll do that.
