2nd Gen Ram 5.9 Magnum weird Casting number
Old Jul 27, 2020 | 03:14 AM
Brian Cunnius's Avatar
Brian Cunnius
Default 2nd Gen Ram 5.9 Magnum weird Casting number
Hey guys. I recently bought a 99 dodge ram 5.9 magnum. The dash says 230xxx. The guy i bought it from claims it was swapped with an engine with 20xxx miles on it. I already know that part is untrue, however the thing does not drive like a 230xxx engine. Ive searched everywhere and even emailed mopar about where the serial number is, i cant find it anywhere. However i did find the casting number. Every casting number on google is 53020006-360. However mine is 53020006AB-360. WHAT DOES THE AB MEAN!? Also if anyone does know where the actual serial is, id love to know. Thanks!
Old Jul 27, 2020 | 08:23 AM
The letters at the end of the part number are just the revision of the part. Their *should* be a date stamp on that same side of the block somewhere, though it is likely not in an easily recognized format. You won't find a serial number on it.
Old Nov 13, 2020 | 12:37 PM
Car Kingz's Avatar
Car Kingz
I believe the engine in your 99 is the 4 wheel drive version put into last 2002-03 models 1500 and 2500. It was just a heavy duty version of the 360 with an additional mounting holes on the block and a change in roller rocker lifters.
