ABS lights
Old Jul 29, 2020 | 05:16 PM
Brandon White's Avatar
Brandon White
Default 1998 Dodge Ram 3.9L V6 ABS Light
Just bought a 3.9l 1998 dodge ram 2wd.. Going through the issues and can't seem to get the ABS and BRAKE lights off. I've replaced the wheel speed sensor with a brand new one and the issue persists. I've used electrical cleaner on the connectors. Im not sure if it's the module because i still have the functioning speedometer, usually it goes out if it's the module. I dont see any frays in the wires and i've also checked the fuses which are all good. Can the trans speed sensor cause these lights? Any help is appreciated. Also- Ran my Cheap OBD2 Reader and got no codes (these are the only lights on)
Old Jul 29, 2020 | 06:29 PM
DerTruck's Avatar
DerTruck
No the trans speed sensor can not cause the lights. Cheap OBDII readers typically can not talk on the CCD bus that interconnects all the different modules in the truck so they can't retrieve ABS codes. There are other failures besides the rear sensor that can set codes, and the module itself is working and sending speed signals to the cluster. On older trucks there was a trick to retrieve ABS codes but that doesn't work on a 98 AFAIK. Best option is to find somebody who has a shop level tool.
Old Jul 29, 2020 | 10:00 PM
2 or 4 wheel abs?
Old Nov 6, 2020 | 12:44 AM
Liddlez's Avatar
Liddlez
Air in the brake system triggered my ABS/BRAKE lights. Once I bled them, they went away.
