CAN the os's be cleaned?
Old Dec 21, 2005 | 11:25 PM
ROWDY69ER's Avatar
ROWDY69ER
Default CAN the os's be cleaned?
can the os's be cleaned or do they have to be replaced,my check engine light came on and it was saying that the one before the cat was getting too hot and the guy out at auto zone said it needed replacing---he says that they cant be cleaned and i also ask him if he thought maybe there was a problem like the cat stopping up causing it or something and he says no ,that the os just needed to be replaced--which cost about 65 bucks,any suggestions,thanks
Old Dec 21, 2005 | 11:30 PM
Socha_62's Avatar
Socha_62
Default RE: CAN the os's be cleaned?
Well I imagine O2s can be cleaned, but not positive.
Your cat could be malfunctioning, or something else. Something thats very funny often occurs. People ALWAYS forget that the O2 sensor actually does something.... 99.9% of the time when there an O2 sensor problem people replace them and don't remember that thay're there to sence something....
Like something that is malfunctioning...
But it is true that they do just go bad more often than not, the little plates on them can get covered in soot and they stop working. But go tell that guy at AutoZone that sensors are there to actually tell if something is wrong with the car, so maybe it IS the cat
But once again, mostly they do just go bad
Old Dec 21, 2005 | 11:57 PM
ROWDY69ER's Avatar
ROWDY69ER
thanks for the reply,that was my thoughts too,but now the light has gone out?i will probably try to clean it first if it gives more problems,but it has came on and off for years now--i just keep an eye on the oil,temp,etc---and keep driving as long as it seems to be running fine,this is the first time i have had it checked,and that was just because they do it for free a auto zone now--i have always felt that these computer chips with all there sensors and check engine light was mainly a way to rip most people off by them running straight to the dealership and paying out the @## for basically nothing because the"check engine light" scares them----thanks
Old Dec 22, 2005 | 01:35 AM
bamory's Avatar
bamory
My CE came on due to O2 sensor, took it out and cleaned it really well with Carb cleaner and toothbrush, that was about 15,000 miles ago, no CE since. So it is possible its just dirty.
Old Dec 22, 2005 | 02:43 PM
steve05ram360's Avatar
steve05ram360
yes it can be cleaned... go to the parts store and get a can of "electronics parts" cleaner and spray it liberaly. let it dry the re-install it. I've done it to my M3 and the Ram, on the M3 I had a CE light for the o2, cleaned the o2 and re-installed it, no problems after that and it runs awesome.
Old Dec 22, 2005 | 11:25 PM
bamory's Avatar
bamory
Never tried electronic spray, i know you don't wanna use acetone or solvents of any sort.
Old Dec 23, 2005 | 12:09 AM
ROWDY69ER's Avatar
ROWDY69ER
HEY---thanks,i will get some from the rat shack and try
Old Dec 23, 2005 | 02:09 AM
dodgefreak's Avatar
dodgefreak
just loose the cat and get a o2 simm from fastman
Old Dec 23, 2005 | 12:01 PM
steve05ram360
ORIGINAL: bamory
the elect. component spray leaves no residue and I think it may not be as harsh as some of the solvents out there.
