any valve body install tricks(help)
Old Dec 22, 2005 | 03:22 PM
chickendukie094's Avatar
chickendukie094
Default any valve body install tricks(help)
i pulled the valve body out of my trans and now i can't pull the shifter out of park. the shifter rod inside the trans goes into a tunnel , everything is fitting rite but end result su**ks. is there some kind of trick for installing the valve body. this is the first time i've tried.
thanks
Old Dec 22, 2005 | 05:40 PM
94Champ's Avatar
94Champ
Default RE: any valve body install tricks(help)
Hi,Just some quick thoughts:
1-Does the shifter cycle thru all the gear selections without being hooked up to the valve body?
2-Does the "rooster comb" on the valve body cycle thru all the gears and do the detents work [without being hooked up to any linkage,see pic of rooster comb below]
3- Is the shift linkage installed in its proper orientation? [see pic below]
4-The park sprag rod c-clip should be facing the valve body when installed correctly[I don't have a picture of that], just some thoughts,if the park pawl is stuck, rocking the truck may free it, but most likely you would have to disassemble the od unit to repair it.
5-The adjustment of the shift linkage is critical to proper operation.With the shifter in park,the valve body shift arm should be all the way rearward.[no more rearward movement possible,but just at that point,no more]
[this post may end up with duplicate pix,having problem with connection ]
[IMG]local://upfiles/23203/E450997593C049A8B14B549BAAAAF0C1.jpg[/IMG]
[IMG]local://upfiles/23203/9797F85977454B58809C003BBED6EA27.jpg[/IMG]
[IMG]local://upfiles/23203/AB49E6B905B74E8A8B421D446A01B10B.jpg[/IMG]
[IMG]local://upfiles/23203/1E2A86F7D0914FA5A5F06037EC480C1C.jpg[/IMG]
Old Dec 22, 2005 | 05:59 PM
chickendukie094
yes everything is working fine b-4 installation. there is no way i could see where the rooster comb will end up(cant see that far back).going to try again now.
Old Dec 22, 2005 | 08:29 PM
chickendukie094
ok what i found out was you have to bump the drive shaft so that the arm locks in.
