Tail Lights
Old Oct 1, 2020 | 11:39 AM
Cooper.Vashel's Avatar
Cooper.Vashel
Default Tail Lights
I recently bought a '99 Dodge Ram and during the inspection, there was a running light out in the back passenger side however when I took the lights out the still running one worked in each so I ordered more on amazon. When the new lights came I put them in the housing and turned them on and neither of them lit up. So I tried the old light again that I knew worked in both and now is not working as well. I looked at every fuse that has to do with lights none are blown and the connection to the light is good. What else could be the problem?
Old Oct 1, 2020 | 02:11 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Are you getting power to the socket? Turn signals work?
Old Oct 1, 2020 | 04:39 PM
Cooper.Vashel
There is power to the turn signal and brake lights I need to find my multimeter and I'll check if there is power
Old Oct 1, 2020 | 07:17 PM
MoparFanatic21
Did you check the fuse in the dash and under the hood?
Old Oct 2, 2020 | 05:18 PM
Cooper.Vashel
I found the multi-meter and measured it there is power and I found new lights on Amazon turns out I bought the wrong ones! Ahahah
Old Oct 3, 2020 | 01:40 PM
MoparFanatic21
Got to love simple fixes
