My truck has no balls, how to fix?
Old 10-13-2020 | 04:06 AM
Rmgk's Avatar
Rmgk
I would more suspect that the trans is indeed starting out in second, and the 'gears' you are getting is 2nd, 3ed, and TCC engage.
I just double checked by putting it in 2, it shifts so that’s more proof that it does start in first. However, I have driven only 2nd gens since I was 14, so I’m pretty sure I know what first feels like. Not to mention, this truck was this slow since before the pcm swap so that wouldn’t be the issue
Old 10-13-2020 | 11:35 PM
2bit's Avatar
2bit
If you really want to fix it, depending on how fast you want to run, it needs 4.56 -5.13 gears to run 37s. Maybe even lower if you want power and don't care about running fast. I'm putting 4.88s in my Ford Excursion on 35s.
Quick Reply: My truck has no balls, how to fix?
