Front rims getting hot?
Old Oct 24, 2020 | 09:57 AM
Liddlez's Avatar
Liddlez
Default Front rims getting hot?
Hi all. My front rims are getting hot, and I don’t know what it could be. The brake system is new, so it’s not the brakes. The system includes calipers, pads, lines, booster, and cylinder. I suspended the truck and rotated the tires by hand, and they turn smoothly. What could it be? The hottest part of the rim is the center. My truck is a 1996 Dodge RAM 2500 4x4 5.9 360 V8. Thank you.
Old Oct 24, 2020 | 10:06 AM
With the front up in the air, spin the front tires. Take note of how much effort it takes to turn them. Step HARD on the brakes a couple times, and try again, is the effort required about the same?
Old Oct 24, 2020 | 10:08 AM
Liddlez's Avatar
Liddlez
We did that last night actually. It was the same very smoothly.
Old Oct 24, 2020 | 10:09 AM
Depending on how hot they are getting..... it might simply be normal then. Generally, if they aren't smoking when I stop, I pretty much ignore them. Only other thing I could think of that might cause them to be excessively hot, is the bearings being on their way out.
Old Oct 25, 2020 | 08:46 AM
Moparite's Avatar
Moparite
Take it out for a drive to the point it gets hot then lift it and check things out. I had a brake line (flexible) where the metal supports hold it rust up to the point it would trap pressure in the line and cause the pads to drag on the rotor.
