Severe uneven pad wear.
Old Oct 30, 2020 | 11:50 AM
ol' grouch's Avatar
ol' grouch
Cylinders are so cheap though, simply replacing them seems to be the go-to method of repair.
I've had odd ***** through the years where they were made of unobtanium.
Old Oct 30, 2020 | 12:53 PM
Yeah, there is that...... Also, if you are on a really tight budget, rebuild kits are cheaper, but, by the time you buy the hone, and the kits, likely surpassed the cost of new cylinders....... (provided you can find them.....)
Old Nov 1, 2020 | 09:19 PM
ddtmoto's Avatar
ddtmoto
Replace springs, adjusters, all hardware as well....
Old Nov 2, 2020 | 07:29 AM
Sheriff420's Avatar
Sheriff420
The last time I replaced one was because the fluid leaking out of it made the brakes super grabby on that wheel. I went to put the new one on and it didn't fit. I returned that and compared it to others with the same part number that I confirmed myself thinking that the parts store messed up. It was the right part number but it just wouldn't fit so I had to grind a little off the body to make it fit.
Old Nov 11, 2020 | 10:54 PM
Liddlez's Avatar
Liddlez
I’ve replaced the cylinders with one ton cylinders, and my brakes are better than ever, thank you all!
