Squeaking noise at idle
Old Oct 29, 2020 | 07:54 PM
Parker Houston's Avatar
Parker Houston
Default Squeaking noise at idle
When my truck is idling in park or drive there’s a high pitched squeak coming from what sounds like the engine bay. I’m positive it’s not the belt, I replaced it a few months back. The noise is off and on its not constant so I was thinking it was the idler pulley but not sure. Don’t want to blindly replace parts and spend unnecessary money thanks
Old Oct 29, 2020 | 07:59 PM
ol' grouch's Avatar
ol' grouch
The idler pulley will often do that when it gets age on it. Just about any engine with a serpentine belt can do it. It will usually be worse when it's cold. Spray a little oil onto the pulley from behind onto the bearing. /if the squeek stops, you've found the naughty one.
Old Oct 30, 2020 | 12:52 AM
Ramman18's Avatar
Ramman18
Can also use an extension or similar rod to listen to each pulley as it runs. Just keep you hair from falling in the belt!
Old Oct 30, 2020 | 10:22 AM
A little bit of dirt on one of the pulleys will also give you a squeak, or a weak belt tensioner.
Old Oct 31, 2020 | 08:52 AM
Moparite's Avatar
Moparite
Well my truck has done this every time i have replaced the belt. The pulleys wear (get shiny) and when you put a new belt on it can cause it to squeak until the belt wears in then it will stop. This is if all the other factors check out to be good.
Old Oct 31, 2020 | 12:01 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
This right here I went through 5 belts when I was younger until my dad told me that
