Crossmember removal 2nd gen 2wd
Old Nov 8, 2020 | 08:47 PM
Xombi's Avatar
Xombi
Default Crossmember removal 2nd gen 2wd
2001 ram 2500 2wd 5.9 v8.
Got the trans 46re loose and would like to drop the crossmember. Removed the bolts. It appears to be wider at the top than bottom. Like a u spread at the top. Do you tap it up them slide it out? Beating it down aint working
Old Nov 8, 2020 | 10:01 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I beat it the rear of the truck and it drops right out.
Old Nov 8, 2020 | 10:18 PM
Xombi's Avatar
Xombi
You beat it toward the rear of the truck?
Old Nov 9, 2020 | 01:25 AM
MoparFanatic21
Yep jack up the transmission so it's not in the Crossmember, beat it towards the rear a few inches and it will fall right out
