Flexplate question corresponding to crank or converter
I didn't even realize that there was an offset hole for it I put tit up to the crank and started putting bolts in no problem.... I gotta stop blindly working and take my time before I ruin something. Thank you sir, was thinking I'd have to separate the two again.
I've been thinking, (Now my head hurts.) Did you pinch it when you put it in there? No wonder you don't want to do that again!!
Reason: i kent spel wurth a durn.
That's one of those lessons you learn really well. You can use blue locker but on the flex plate I often use red. Just NEVER use red on aluminum threads. It'll pull the threads out.
I used red, I like to make sure that it stays there until i decide to remove it. and thanks for heads up on that with aluminum haven't come across that cicero yet.
