5.2 manual transmission
Old Nov 24, 2020 | 10:19 PM
Twangin4u's Avatar
Twangin4u
Default 5.2 manual transmission
If I swapped a pcm from a 5.9l automatic to a 5.2l manual transmission will it run?
Old Nov 25, 2020 | 01:23 AM
DerTruck's Avatar
DerTruck
It might. The big question mark is that the auto PCM has an input for the park/neutral switch on the transmission while the manual doesn't. Worst case you could ground that pin on the PCM. It won't run perfectly though as the calibration is a little off.
