Crank but no start Intermittent power to ignition coil
Old Dec 2, 2020 | 03:15 PM
Doug Scott's Avatar
Doug Scott
Default Crank but no start Intermittent power to ignition coil
2000 Dodge Ram 1500 with the 5.2 liter v-8 cranks but does not start. I have already replaced the asd and ignition coil and at this point I am getting power through the coil for about 1 second during cranking but then lose power to it I am receiving 12 volts when I do have power at the coil.
Old Dec 2, 2020 | 03:52 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Sounds like the crank sensor
Old Dec 2, 2020 | 07:15 PM
Moparite's Avatar
Moparite
??? Asd relay gives power (12V) to the coil while cranking. If the ignition is on(without cranking) you will only have it for a short period. Is the battery fully charged?
