Fuel gauge
Old Dec 6, 2020 | 08:54 AM
99flatbed5.9/24v's Avatar
99flatbed5.9/24v
Default Fuel gauge
Turn key on fuel gauge goes to 1/2 tank and stays
new in tank sender. Wires chased no bare spots rubbing. Replaced connector on top of tank. Tried aftermarket gauge same results.
Old Dec 6, 2020 | 09:11 AM
Is the float stuck? If the pump module isn't clocked properly, it'll hit the side of the tank.
Old Dec 6, 2020 | 03:13 PM
DerTruck's Avatar
DerTruck
Did you check the resistance of the fuel level sender ? It should be between 20 ohms (all up) and 220 ohms (all down). If it never changes then there's still an issue with the fuel pump module.
Old Dec 7, 2020 | 09:34 AM
Moparite's Avatar
Moparite
Yeah, Did you do this? Can't just put it in any way.
