Fuel questions.
Old Dec 13, 2020 | 03:35 PM
Lakerat2311's Avatar
Lakerat2311
Default Fuel questions.
So first post here, and as a complete Mopar new guy, have little to go on for my planned build. I have a 98 1500 with the 5.9 magnum in it, and I plan on doing some sprucing up. I will be replacing the intake manifold with one of the Hughes airgap numbers, new MSD ignition setup, dual roller timing setup, and dropping a load on heads and a cam eventually. Y main question is this, I know the stock injectors are around 20ish#, but where should I aim if I am replacing them and want a better flow? I have my eye on a set of 34# injectors form Accel. Does that sound about right? The bottom end is solid already, and I don't plan on messing with it unless I have to.
Any input on the best injectors to run with the current list of mods would be appreciated.
Old Dec 13, 2020 | 04:07 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The stock injectors are good unless you are making big numbers. I am building a 600hp 408 and the stock injectors are sufficient. Only way I would have to upgrade is more power or if I decide to turbo
