No bus
Old Dec 13, 2020 | 07:41 PM
1500ramgirl's Avatar
1500ramgirl
Default No bus
I recently bought a RAM 1500 Sport from a private owner and was getting all needed maintenance work done by my mechanic and the NO BUS started flashing. Bought a new alternator and juiced up my battery but still won't turn on and when we jump it doesn't stay on and shuts off and won't turn on by itself. Would a hard reset be good.......i need this truck to run to haul woods to keep us warm for the winter and just needs around the house. please help.
Old Dec 14, 2020 | 08:24 AM
What year is the truck?
Old Dec 14, 2020 | 09:16 AM
1500ramgirl
2001 ram. Do all rams have this problem. If it is this the last one that I am purchasing
Old Dec 14, 2020 | 09:35 AM
Gonna move this to the 2nd gen ram tech section for ya.
"No Bus" means the cluster has lost communication with the PCM. Generally, its caused by one of the sensors on the 5 volt bus failing/shorting out, and taking down the whole system. (yeah, not a good design, really.....) Since yours won't start, I would immediately suspect either the cam, or crank position sensor. Trouble is, there isn't a good way to test those, without having a fairly high zoot scanner, or o-scope..... Could try unplugging them, one at a time, and see if the cluster comes back. (of course, the engine still won't start, even if the cluster does come back.....)
