2000 Dodge Ram 1500 2WD Tie Rod Help
Old Dec 17, 2020 | 08:04 PM
Burner657's Avatar
Burner657
Default 2000 Dodge Ram 1500 2WD Tie Rod Help
Hey, I've got a 2000 Dodge Ram 1500 2WD 5.2 V8 and I'm kind of stuck. I'm replacing my driver's side tie rods (inner and outer) and the adjusting sleeve. Is there a trick to getting the inner tie rod out? It's like the boot is too big, it just hits the frame rail behind it. Do I have to remove the boots on the sway bar and pull the sway bar down as well to replace the tie rods?
