01 1500 4x4 drivers side axle nut
Old Dec 20, 2020 | 01:39 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by 1SaltyGreenBean
Understood. Guess I'll be on my back tomorrow. Also I need to get a real service manual somewhere. You just saved me a ton of time. For that I Thank you. Would you try a regular high grade bolt on the one I cut or do I need the adjustable one. Having trouble finding one.
If you can save the adjustable washers and but the adjustment bolt
Old Dec 20, 2020 | 08:32 AM
1SaltyGreenBean's Avatar
1SaltyGreenBean
Originally Posted by AtomicDog
Service manual for your truck can be found here:
https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Thanks you for this. Went right to what I'm working on.
Old Dec 20, 2020 | 08:33 AM
1SaltyGreenBean
Should be able to save the adjustable washer. Already have one off. Thanks again!!
Old Dec 20, 2020 | 12:17 PM
MoparFanatic21
You are welcome! Only reason I say to save them is the aftermarket ones are smaller so you lose I think 1-2° of adjustment
Old Dec 21, 2020 | 05:52 PM
1SaltyGreenBean
Default Update
It's amazing what you can do with the help of you guys, and a new saws all blade. Was able to cut the lower control arm off. got the new one already, just waiting for the bolt. I think will a little TLC on the inside washer, they will work fine. And I apologize again for starting a thread with one problem but really having at least three!!!
Old Dec 21, 2020 | 10:43 PM
MoparFanatic21
Glad we could help!
