electrical problem
Old Dec 21, 2020 | 04:27 PM
scottmedley's Avatar
scottmedley
Default electrical problem
I currently own a 98 Dodge Ram 5.2 L four-wheel drive the problem I am having that started two days ago when you turn the left turn signal on the wipers come on I replaced the switch and it's still doing the same thing the driver side headlight is dimmer than the passenger side I've replaced the bulb and still the same problem any feedback on how to solve this problem would be appreciated
Old Dec 21, 2020 | 06:01 PM
For the wipers/turn signals, check the connector at the switch. If you have tilt wheel, and it gets put all the way up, it can pull wires out of the connector a bit, and you get weird problems.
For the headlight, check the ground. If you don't have one yet, you can get a service manual for your truck from here. Wiring diagrams and such are in section 8W.
