2000 1500
Old Dec 23, 2020 | 04:48 PM
Neil Doyle's Avatar
Neil Doyle
Default 2000 1500
Hey guys n gals. I have a 2000 ram 1500 5.9.
stopped at a stop sign and noticed what I thought was smoke coming from under the hood . Got er home just as temp was hitting 120. Blowing straight cold air . no leaking hoses but no coolant in rad. Did.notice small goldish flakes under rad cap tho. Water pump maybe? Any ideas would be greatly appreciated
Old Dec 23, 2020 | 08:13 PM
The goldish flakes were probably from some variety of stop-leak someone put in to cover the leaking head gasket...... That coolant is going somewhere.
Old Dec 23, 2020 | 08:56 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Smoke under the hood is either coolant leaking and burning up or over heating. Since you said the gauge said 120 you weren't overheating. These trucks are known for cracked heads and will burn coolant and oil. That's where mine was going in my one 2nd gen. They wouldn't explain the smoke under the hood
Old Dec 23, 2020 | 10:31 PM
jasmoore3's Avatar
jasmoore3
Your temp reading will always show low if you are out of coolant, yet your engine will be overheated. Hope you didn't crack your head(s), Probably just a head gasket or if your lucky a freeze plug or hose.
Old Dec 24, 2020 | 06:20 AM
My question becomes, is the Fahrenheit, or Celsius?
