Trans temp and O/D light
Old Dec 26, 2020 | 04:37 PM
Phillip Preston's Avatar
Phillip Preston
Default Trans temp and O/D light
I have a 2000 Ram 1500 5.9 4x4. The Trans Temp and O/D Off light come on sporadically. They will jump on about every 2 minutes and then turn off within 5 to 10 seconds. The transmission was replaced 2 years ago by the previous owner (With transmission shop paperwork to prove). There is a TINY leak at the bell housing, but I don't think that is responsible. Any thoughts or advice would be appreciated. I have read that it could be the Governor Pressure Sensor/Solenoid could be the issue as the temp sensor is built into it?
Old Dec 26, 2020 | 05:12 PM
Temp sensor is part of the pressure sensor. If the PCM thinks the trans is getting too hot, it will disable O/D. Think I would start with replacing that sensor, and having a look at the check valve in the trans line.
Welcome to DF!
