transfer case problems
Old Jan 3, 2021 | 12:04 PM
jollygreen's Avatar
jollygreen
Default transfer case problems
i have a 2001 1500 4 wheel drive and the transfer case will not stay in 2 wheel high i cannot drive it like this 4 low works 4 high works and 2 high works till you start down the road then it works its way into neutral can anyone tell how to repair or correct this problem
Old Jan 3, 2021 | 02:20 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Did you ever check the snap ring on the output shaft?
Old Jan 3, 2021 | 03:15 PM
I would be tempted to look at the shift linkage as well. If it's sloppy, it may not be engaging all the way.
