1997 Ram 2500 5.9 Diesel Indep Front Susp Axel Nut
Old Jan 9, 2021 | 11:00 PM
tomsd's Avatar
tomsd
Default 1997 Ram 2500 5.9 Diesel Indep Front Susp Axel Nut
Hello,
I just changed my inner/outer tie rods, inner and outer (tapered) wheel bearings, shocks, ball joints and all front bushings. As I was finishing, and installing the rotors attached to the spindle by an axle nut, I am at a crossroads. The manual suggests that I tighten the axle nut to 20 lbs, then back it back 1/4 turn, then hand tighten the axle nut and install the cotter pin. CAN THIS BE RIGHT? All that is holding on my tire/rotor is a hand tightened axle nut with a cotter pin?
Please help.
Again: 1997 Dodge Ram 5.9 Diesel 2WD, Indep Front Susp
Thank you
Tom
Old Jan 9, 2021 | 11:33 PM
DerTruck's Avatar
DerTruck
Yup, just like any old school drum brake or trailer axle.
