No start after truck is warmed up...
Old Jan 17, 2021 | 01:13 PM
Toby Hammett's Avatar
Toby Hammett
Default No start after truck is warmed up...
I have A 98 5.9/360 gas engine and I've had the following happen twice in the last month - so she has always started up very quickly, and after starting and driving a few miles and turning it off, when I come back to the truck to start it again she will crank strong as hell but will not fire up - if I had no other knowledge of the truck I would assume I have no fuel but as noted, I just drove it fine. So after a few minutes I hold the gas pedal down to the floor, may have pumped it once or twice and bam, she fired up. About a month later same exact occurrence, after driving with no issues it didn't start, waited a few minutes and stomped the pedal to the floor and she started right up.
So the question is, is this indicative of a common issue that one of you know about? Maybe its not a fuel issue but it sure feels like one, many thanks -
Old Jan 17, 2021 | 03:08 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Sounds like it's getting flooded. It could be a couple of things most common being a bad coolant temp sensor or the wiring. Another possibility is a leaking fuel injector(s)
