Transmission oil cooler line disconnect clip
Old Jan 18, 2021 | 07:53 PM
Lriwater's Avatar
Lriwater
Default Transmission oil cooler line disconnect clip
Hello,
I am replacing the rubber tranny oil cooling lines with the quick disconnects at the tranny oil cooler. One line was not leaking and had this retaining clip on it, and the other one was leaking and had no clip. I can't find that clip anywhere, not even the dealer. My truck is an '01 2500 diesel. Any suggestions as to where to get them or if I need them at all? A lot of repair pictures I see don't have the clips, but maybe they have already removed them.
Many thanks in advance,
Chuck
Old Jan 19, 2021 | 01:40 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Lriwater
Hello,
Chuck
Not needed
Old Jan 19, 2021 | 09:19 AM
Yep, not needed. I see those on fuel lines on a fairly regular basis, but, they aren't really needed there either. The quick-connects hold on pretty good. There are O-rings inside that seal them. I think you can replace them, as opposed to replacing the entire connector.
Old Jan 19, 2021 | 05:14 PM
Lriwater's Avatar
Lriwater
Great. Thanks!
