Crack in frame
Old Jan 19, 2021 | 07:06 PM
Rlynnday's Avatar
Rlynnday
Default Crack in frame
Hey guys and gals. I've got a 2001 Dodge Ram 3.9L with a crack in the frame under the passenger side, just about directly below the gap between the bed and cab.
No idea how long it's been there that I've been driving on it - just found out when I went to have tires changed today.
Wondering if it can be fixed, should be fixed, about how much a fix would cost if so, and how reasonable it is that I could continue driving it locally for a brief time?
Old Jan 19, 2021 | 07:37 PM
AtomicDog's Avatar
AtomicDog
Frame cracks are something that should be fixed. In this area, there are several welders that enjoy repairing rusted/cracked frames on vehicles. I recently had a rusted area in my frame just behind the passenger side control arm repaired. The welder came to my home and did the repair in my driveway.
Old Jan 19, 2021 | 08:46 PM
Rlynnday's Avatar
Rlynnday
Thanks so much! I figured either it needed fixed or scrapped, and I'd rather fixed - but the tire shop today told me no one would likely want to do it because of liability. Also, I live in rural KS, so I don't have access to as many people as in a larger city, or as many skilled professionals. But I will certainly put out word. How much did it cost for your repair?
Old Jan 28, 2021 | 09:48 PM
1SaltyGreenBean's Avatar
1SaltyGreenBean
If you cannot weld, find some to weld up the crack and then weld in two plates on the outside and inside of the frame at least the same size thickness of the frame itself. Keep on getting up. I've actually done this on a smaller truck and just bolted the two plates to the frame. Around here maybe $200 to $300.
