John Deere HyGard fluid in 46/47RE?!
Old Feb 5, 2021 | 02:09 PM
Liddlez's Avatar
Liddlez
Default John Deere HyGard fluid in 46/47RE?!
I was conversing with a fellow 2nd Gen owner who claims to run his 47RE with John Deere HyGard which literary left me speechless. Has anybody ever heard of this..insanity? I’d never in a million years attempt to run anything BUT Mopar ATF+4 in my. 46RE.
Old Feb 5, 2021 | 04:27 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Only ever ran ATF+4 wasn't Mopar brand though. I did also use some thick oil when I knew it was going just to get me by until the weekend
Old Feb 5, 2021 | 04:28 PM
The john deere stuff is hydraulic fluid. Good for hydrostatic transmissions and such. I wouldn't run anything other than ATF +4 in my dodge trans.
Old Feb 5, 2021 | 09:40 PM
Liddlez's Avatar
Liddlez
what do you mean by “thick oil” an additive, or engine oil? 😳
Old Feb 5, 2021 | 09:42 PM
Liddlez's Avatar
Liddlez
Agreed! Also, what do you think about coolers? I currently have a 30,000 GVWR cooler on mine, but I want a 40,000 one instead. Is it an overkill, is there such thing as “too cool”? I don’t tow or haul at all. Literally the only “cargo” in the cab is myself or a passenger.
Old Feb 5, 2021 | 09:49 PM
MoparFanatic21
An additive and motor oil. Only because I knew it was going bad and just had to make it to the weekend. That was in a 98 Durango with a 360
Old Feb 6, 2021 | 09:21 AM
Then even the 30K cooler is overkill. Is that a 'bad thing'? I don't think so. Heat is what kills your trans. But, over-cooling doesn't help it either. Think I would go for a trans temp gauge before upgrading the cooler. You likely don't need it.
Old Feb 7, 2021 | 04:29 AM
Liddlez's Avatar
Liddlez
Do you still think it’s an overkill if my climate is extremely hot? *cough cough* Texas. 😂
Old Feb 7, 2021 | 09:19 AM
Moparite's Avatar
Moparite
What might be a better idea is running a 180 stat instead of the 195. That will lower the running temp of both engine and trans.
Old Feb 7, 2021 | 09:40 AM
It do get warm there.
Install the gauge, see what temps look like, go from there.
