Transfer Case Identification
Old Feb 19, 2021 | 10:38 AM
Browntown's Avatar
Browntown
Default Transfer Case Identification
I have a 1995 Dodge Cummins 2500 and currently finishing up a rebuild of the transmission. It is an automatic with the 47RH installed. I am not the original owner so do not know the full maintenance history but the current trans had been rebuild at some previous point. In checking out the transfer case I noticed the back plate has it listed at a NP231D. To the best of my knowledge the '95 2500's used the NP241DHD. Will this be an issue and should I find a new transfer case?
Old Feb 19, 2021 | 10:48 AM
Hhhmmm.... that seems like a pretty lightweight t-case for a 2500. Given you have the diesel, I seriously doubt it is the light duty 2500..... So, yeah, should be at least the NP241D, if not the DHD...... (DHD has a slightly wider chain.)
If you are going to tow/haul with it, I would be considering finding the correct t-case.
Old Feb 19, 2021 | 10:57 AM
Browntown's Avatar
Browntown
Thank you, I'll start looking since its still up on the lift. Had me stumped for a moment.
Old Feb 19, 2021 | 11:09 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
This happened to me. I bought a Cummins and the PO tried to install a NV3500 from a 1500 with the 1500 transfer case
Old Feb 19, 2021 | 11:12 AM
Browntown's Avatar
Browntown
I'm trying to have a contact of mine at Chrysler pull up the original records by VIN to see just what's what with the rig.
Old Feb 19, 2021 | 11:15 AM
Go here, feed it your VIN, and it will tell you.
Old Feb 19, 2021 | 11:27 AM
Browntown's Avatar
Browntown
Thanks will give it a try.
