A/C Compressor Problems
Old Feb 23, 2021 | 05:09 PM
DeLoreandude's Avatar
DeLoreandude
Default A/C Compressor Problems
I have a 98 ram 1500 with the 5.2L 318 and there is a problem with the air conditioning. The A/C wasn't working when I bought the truck, so i figured it needed R-134a and while I was right, it was low now the compressor constantly turns on and off at like 3-5 second intervals. What's wrong with it? And what should I do?
Old Feb 23, 2021 | 05:15 PM
Spillage's Avatar
Spillage
Still not enough refrigerant...
Old Feb 23, 2021 | 08:45 PM
Need to put gauges on it. Most of the cans with a gauge on 'em, will have a chart on the can as well, that tells you what your low pressure should be (compressor running) given the current temp.
Old Feb 24, 2021 | 06:45 AM
Moparite's Avatar
Moparite
If it wasn't working when you got it it probably has a leak. And with it being empty then you have an idea how much refrigerant to put in. You may want to add die to locate any possible future leaks.
