5.9 magnum won’t start with out the OBD2 reader hooked up
Old Mar 5, 2021 | 10:21 AM
Lathan Tinder's Avatar
Lathan Tinder
Default 5.9 magnum won’t start with out the OBD2 reader hooked up
I have a 2000 5.9 magnum 1500 with 150k miles on it. It was my first vehicle and drove it everyday until it started acting up and I couldn’t fix it so I’ve come here for help.The truck won’t start now unless the OBD2 reader is plugged in and even then it runs rough,and if you unplug the scan tool the truck will die and won’t start back up.
Old Mar 5, 2021 | 02:40 PM
Does your scan tool show any codes? Or pending codes?
Old Mar 5, 2021 | 02:57 PM
Lathan Tinder
The scan tool doesn’t show a code
Old Mar 5, 2021 | 03:37 PM
Verify you are getting spark, and fuel pressure.
Old Mar 6, 2021 | 01:34 AM
DerTruck's Avatar
DerTruck
Start with the basics, power and more likely grounds. The data link connector has two pins (4 & 5) that connect to different grounds in the vehicle. The ground on pin 5 is the same that the PCM uses, might be the scan tool connects the two pins internally and provides a temporary (and crappy) ground. Pin 5 goes to G105 on the front of the engine, black/tan wire. .
