P0720, P0301, Uncontrolled downshifting.
Old Mar 12, 2021 | 12:09 PM
wrnchbndr's Avatar
wrnchbndr
Default P0720, P0301, Uncontrolled downshifting.
Truck normally runs well but more and more I started to get a Service Engine light. Then, it started to randomly downshift at any speed over 40mPH - from OD to 4th, to 3rd as if I was encountering a hill. I did my research. Crank position sensor for the P0301 and the transmission speed sensor for P0720. HOWEVER. All I did was clean the connectors going to these sensors and the problem was fixed. I used Deoxit, and generic spray contact cleaner. It’s worth your time to just try cleaning your connectors before you order parts. In the end, I ended up separating and thoroughly cleaning every electrical connector under the hood and on the transmission. This took me less than 30 minutes.
Old Mar 12, 2021 | 05:10 PM
69_XS29L's Avatar
69_XS29L
Nicely done, the internet parrots would have had you (buying)changing unneeded parts immediately.
I imagine there have been more than a few repairs accomplished not by the new sensor installed, but by undoing the connection during the changeout.
Old Mar 12, 2021 | 10:18 PM
DerTruck's Avatar
DerTruck
Similar story: About a year ago the ABS started acting up with a motor circuit error (don't remember the exact code). Some contact cleaner in the connectors, exercised the ABS a few times on a dirt road and it's been happy ever since.
