1998 Dodge Ram 3500 Quad Cab Smokey Remap
Old Mar 16, 2021 | 12:44 PM
Flinty's Avatar
Flinty
Default 1998 Dodge Ram 3500 Quad Cab Smokey Remap
Hi,
Is it possible to remap a 98 dodge ram 3500 5.9 L6 Turbo Diesel with a smokey map so I can roll coal?
Old Mar 16, 2021 | 02:30 PM
Don't let any of the environmentalists see this thread.......
Old Mar 20, 2021 | 11:59 AM
Mike Holmen's Avatar
Mike Holmen
Yah there is some red neck mod for the boost sensor on the head. Some guys just run a switch to switch between.
I just used larger injectors. The largest injectors I ran on stock HX-35 was 6X12's injectors (also ran water/meth) to cut the egt's. Worked well for years. You could also lower the injector pop pressure to make them haze at idle.
