Lost electrical after timing cover gasket??
Old Mar 23, 2021 | 07:15 PM
clappedoutchris's Avatar
clappedoutchris
Default Lost electrical after timing cover gasket??
ok so long story short, yesterday i changed out my timing cover gasket due to that leaking. while doing so, I removed my a/c compressor since that's been seized up well before i bought it, using a shorter belt. Once the job was done, I noticed my check gage light was on and the volt gage was reading 10, but drop to zero after a minute or two. I went over the battery with a tester and it was reading fine. Even after the truck was turned on and off dozen times. So I risked it and drove home (about 30 minutes). Today I drove the truck doing some running around, volt gage was still acting up though. Then as Im on my way home the air bag light cam on, then a minute later the radio stopped working, then a few more minutes later the cluster went out (which gave me no blinkers, head lights, tails and probably brake lights). Yet the truck drove fine. Once I got home I parked and shut the motor off. wouldn't restart. Just get get a little chug from the starter and nothing.
So would the alt maybe have a poor connection finally draining the battery? did either of the two plugs for the a/c compressor cause issues? Any help would be highly appreciated.
Old Mar 23, 2021 | 07:44 PM
Moparite's Avatar
Moparite
Vehicle info? Did you happen to clean the battery terminals?
Old Mar 23, 2021 | 08:10 PM
clappedoutchris
sorry, its an 01 ram 1500 with the 5.9 magnum (auto 4x4)
was just messing with it a little and I'm fairly certain its a charging issue. boosted it and got it running, but only had 7 volts.
Old Mar 23, 2021 | 09:50 PM
2bit's Avatar
2bit
Did you clean all the terminals? There are some ground wires that attach there also.
Old Mar 23, 2021 | 11:28 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
To my knowledge you can't buy a shorter belt have to buy the AC bypass pulley
Old Mar 23, 2021 | 11:41 PM
clappedoutchris
going to pull the alt in the morning to check all the connections and clean everything. battery is about a year old so shouldnt be that. hoping its just poor connection from being apart.
there is a belt to bypass the ac. even the sticker on the rad support showing the belt path, shows it bypassing the ac
Old Mar 23, 2021 | 11:46 PM
DerTruck's Avatar
DerTruck
You sure can, see the "Accessory Drive" section in the FSM. No additional pulley.
Old Mar 24, 2021 | 12:20 AM
MoparFanatic21
Well I'll be, learn something new everyday everyone I've seen had the AC bypass pulley
Old Mar 24, 2021 | 06:41 AM
Moparite's Avatar
Moparite
Might want to check the fuse first.
Old Mar 24, 2021 | 07:14 PM
clappedoutchris
I did a little digging this am and took moparite's suggestion before pulling the alternator. Well luckily I did, blew the 140 amp fuse. Spent the afternoon searching for one and after 8 parts stores (including a napa warehouse) who only had up to 100amp. I had to hit the dealer, which they had to order in for tomorrow.
Seems like I forgot the #1 rule of working on anything to do with vehicle electronics, DISCONNECT the battery.
