Temp gauge question
Old Apr 1, 2021 | 08:34 PM
Steeler80's Avatar
Steeler80
Default Temp gauge question
The temperature gauge in my 2001 Ram 1500 started fluctuating at rimes and would run at normal temp other times. I replaced the temp sensor but the pigtail/socket came apart when I took it off the old sensor. I put the socket back together and plugged it into the sensor. Now, the temp just reads over to the right. I've changed the sensor and still the same thing. I would suspect that the socket is just bad but a mechanic friend looked at it and thinks the socket is still good and attaching fine. I also performed a gauge test and the temp gauge calibrated like the rest of the gauges.
Old Apr 1, 2021 | 08:39 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I would suspect the socket or just a crappy temperature sensor.
Old Apr 1, 2021 | 08:43 PM
Steeler80's Avatar
Steeler80
Thanks! I forgot to add that I thought the sensor might be bad so I tried another new sensor with the same results. I've bought a new socket so I'll try to wire that in and see if that works.
Old Apr 1, 2021 | 08:45 PM
MoparFanatic21
Thanks! I forgot to add that I thought the sensor might be bad so I tried another new sensor with the same results. I've bought a new socket so I'll try to wire that in and sew if that works.
These trucks hate aftermarket sensors. Especially BWD
Old Apr 1, 2021 | 08:48 PM
Steeler80's Avatar
Steeler80
That's what the parts house had, of course! Do I need to try a sensor from Dodge?
Well, the first one was BWD. The second was from NAPA. Im not sure of the brand on that one.
Old Apr 1, 2021 | 09:12 PM
MoparFanatic21
You could. What I would do is replace the connector and see if it changes. If it doesn't then I would try and find the MoPar sensor online as it will be cheaper
Old Apr 1, 2021 | 10:32 PM
DerTruck's Avatar
DerTruck
Needle all the way to the right is very low resistance, possibly a short to ground. Disconnect the sensor and see if the gauge changes. If it doesn't it's probably not the sensor but the wiring. You can also check the sensor with an ohmmeter.
